Dimension.ByElements Trouble
I’m trying to get the Dimension.ByElements node to generate a simple string of dimensions in a section view. But I just can’t seem to figure out why Dynamo keeps throwing an error on that node.
Here’s the error:
“Warning: One or more of the input types are not matching. Couldn’t find a version of ByElements that takes arguments of type (Revit.Elements.Views.SectionView,__array,__array,string,string)”
Any ideas on what I am doing wrong?
Connect elements list to “Reference Elements”. Currently your connecting Reference planes.
Kulkul,
Guess I’m more of a newb than I thought. What are Reference Elements exactly?
I did a search thru the Dynamo Dictionary as well as a Google search, but I didn’t come up with anything about Reference Elements.
Reference elements are the Elements to Dimension. Do this changes in your graph.
@josephprouty Here is a simple workflow showing the process.
Still got the same error when I changed my graph to this,
When I did it the simple way, I was able to get it to complete successfully, however no dimensions actually showed up in Revit. Which I thought was really odd, no?
Could you drop or share the link to your rvt file on google drive /dropbox / wetransfer.
Here you go…
Thanks again for your help Kulkul.
@josephprouty Try this
https://www.dropbox.com/s/xufms896xezhayl/For%20Josephprouty.rar?dl=0
Kulkul,
So I need to use Gridlines in-order for it to work correctly, is that what I was missing?
Kulkul,
One last, rather odd issue I’m running into with this. I am able to get the Dimensions to populate in Revit with the sketch below. However I have to play with the Boolean on the “Element.SelectInView” node, flipping it from True to False and running Dynamo each time I do.
By the looks of it Dynamo is trying to generate the dimensions before it’s generated the Reference Planes. I’ve tried putting a Pause/Wait node in there via Clockwork, but to no avail. Any ideas?
Use Dynamo Player.
Same results with Dynamo Player, unfortunately.
Remove boolean from “Element.SelectInView” node.
@Kulkul
What type of elements does Dimension.ByElement accept? It seems to work fine for walls, grids, etc. But I can’t get it to work for families. It returns an error:
“Warning: Dimension.ByElements operation failed. The references are not geometric references. Parameter name: references”
Line based. Unfortunately that is what we have so far in Revit API :frowning:
That sucks. And I guess if you do a workaround by adding in a detail line it will break the relationship with the non-line based element and opens up a whole can of worms in terms of coordination.
How could I dimension with a line based element, for example a duct or a pipe. It works for the centerline, but if I want to dimension to one edge of the element, how could I do that?.
Thanks a lot. image|564x472
luiggi,
You could have Dynamo place a perpendicular reference plane at the ends of your ductwork, then dimension to that.
