Dimension ByElements
Hi
I am not sure what I am missing in regards to this node.
It seems fairly straight forward but It seems that I am not formatting the Revit elements correctly to get them to work.
Can anyone see something obvious that I am doing wrong?
Thanks!
For this node to work you’ll need to reference the element itself.
Thanks so much Alexander! :smiley:
As far as i know you also must select minimal 2 different elements, your select faces are referring to the same element (read 1 element).
I see. I guess I thought that by turning them into dynamo surfaces and then back to revit faces they would, in the process, lose their relationship to the wall and become 2 elements.
