I have a script that will create views of specific elements (custom Family) with nested components, It is a prefab panel with studs on it.
I need to automatically dimension the distance of the studs (nested family) in this Panel.
It is like a billion panels.
I had no luck so far.
I can create lines using dynamo that would be precisely where the dimension would be but the dimension node just can’t understand my objects(nested elements(family)).
the "Blue lines were created using the Line.ByStartPointEndPoint Node.
I would like to have just the dimension in the Sheet, not even in the view if possible.
I know I can do it manually, but would like to automate the task as it is very repetitive.
