Dimension Foundation
Hi, I’m trying to put dimensions to the structural foundation, but I’ve stayed there, some help.
m
This should work but it also creates detail lines.
Multiple Dimensions#1.dyn (16.8 KB)
Hello, if it works perfectly, but a question in what way I could do it so that it only appears on the left side and the bottom side. Thank you very much
I managed to make it appear on two sides, but when the shoe is rotated it appears next to the right, there is some way to avoid that. Thank you
QC-CO-Zapatas.dyn (22.3 KB)
Probably the settings in revit
It actually creates a detail line the same length of the side and next to it. It then dims the detail line so really not such a good method. But the OOTB node doesn’t work so well.
Can you share the Script or image of the script for better understanding?
It is in the previous comments.
