I’m trying to use your Dimension ByReferences node but am finding problems.
If I use the longest lacing, I am getting duplicate dimensions despite only one dimension (per view) being output from the node.
Updating the input data structure to Auto is also failing
It seems to be an issue with the lacing but I can’t figure out what. If I have more than 2 references I need to use longest lacing. But if I only have 2 references, I need to use shortest lacing. Is this correct?
What am I doing wrong?
