I’ve made a graph for dimensioning curtain walls, now I’m trying to adapt it for linked curtain walls. I’m getting the geometry and it looks like a set of references too, but the dimensions are still null.
Hi @TurtleWolfe,
You probably need the *Convert Linked Reference * node with a link instance input.
Am I still not using it right?
Is Select Element from Link different than what you mean by link instance input?
Dimension Linked CurtainWall 003.dyn (115.8 KB)
@Alban_de_Chasteigner
technically that does seem to answer my original question, but I was making this for the rest of the company to run in dynamo player and apparently that node doesn’t show up there.
Which node ? Select Linked Element ? You probably can replace it or use the refresh input with a boolean set to Is Input.
If feels a little different than the others, I didn’t see the finish button at first. I think I can make it work now. Thank you.
