Hello people!
So I was trying to create a BoundingBox and get its min, max and center point with a python node, but I get different values than with a Dynamo Node.
Does anyone know why? Are these two based on two different coordinate systems?
I tought maybe there was a Problem with the Units conversion in Python, so I tried using the UnitUtils method but that was not it…
clr.AddReference("System")
clr.AddReference("RevitAPI")
UIunit = Document.GetUnits(doc).GetFormatOptions(UnitType.UT_Length).DisplayUnits
# Die Eingaben für diesen Block werden in Form einer Liste in den IN-Variablen gespeichert.
dataEnteringNode = IN
elements = UnwrapElement(IN[0])
# Code unterhalb dieser Linie platzieren
elem_box = []
mins = []
max = []
centre = []
for item in elements:
elem_box.append(item.get_BoundingBox(None))
for item in elem_box:
mins.append(item.Min.Z)
# Weisen Sie Ihre Ausgabe der OUT-Variablen zu.
OUT = mins
