Dictionary from Geometry and Key
Is it possible to create a dictionary with geometry ( in my case ModelCurves ) and keys ?
A bit of background why i need it :slight_smile:
I have a n-sided polygon. Each side is made up of n-numbers of ModelCurves. I am modifying each curve separately. i.e, in the given image I am offsetting crv9 to 3m , crv8 to 1m and crv7 to -1, but all three curves remain a part of side ā€˜e’. So after modification I can recall all three curves just by giving key/index ā€˜e’.
My initial setup is like this ( image ). I select each ModelCurve manually in order and I get a list of 10 items.
Current list structure = [ 0,1,2, 3,4,5,6,7,8,9 ]
Required list structure = [ a:(1), b:(2,3), c:(4,5),d:(6), e:(7,8,9) ]
I dont mind typing a, b,c while selecting curves, but I should be able to recall each curve by their respective side alphatbet. Or in more simple words, i want to group each side with key. I was thinking Dictionary or similar function could be helpful where I could assign key to a set of curves. Is it possible ?
Hi @hassan.orion ,
Sure, take a look at this approach:
2022-07-22 Dictionary from Curve direction.dyn (33.6 KB)
grouping by vector is not enough.
these lines have the same vector, but should not be grouped together.
they should have the same vector and they should be touching
@Daan , it worked like charm. Just had to tweak some nodes since I am not using Dynamo2.
@timhevel , I understand the limitation of the graph. If I already had such shape, i would group it like this (image)
