Determine if a solid has holes
#1
So i’m trying to find a way to determine if a solid has a hole inside of it
For example, in this picture we can see that the solid has a hole inside of it.
How do i get that in dynamo?
Thank you!
#2
i tried something
#3
You could examine the perimeter curves of each face. Group the curves into curve loops. Faces with more than one curve loop have an opening/recess.
#4
This is a fast, not very elegant, valid for one object at a time, script. The idea is the same suggested by @Andreas_Dieckmann, you can use Loops property to get the boundaries of your faces. If you get more loops that faces, than you have a hole.
clr.AddReference('RevitAPI')
clr.AddReference('DSCoreNodes')
import DSCore
from DSCore import *
element = UnwrapElement(IN[0])
faces = []
loops = []
for elements in element:
faces.append(elements)
a = elements.Loops
loops.append(a)
r = List.Flatten(faces,1)
c = len(r)
t = List.Flatten(loops,1)
d = len(t)
if c == d:
out = "no holes"
out = "it has holes"
OUT = out
It’s a just a draft, it has to be improved a lot, for example allowing multiple input, but one has to start from something :wink:
#5
What is a curve loop? how do i implement that?
#6
Unfortunately i can’t improve this code… i don’t know anything about the revit API
#7
Loops are the boundaries of the solid faces. If a face has one hole, it has two boundaries: one outside (the face) and one inside (the hole).
Maybe someone can help, or I will try in the next days
#9
This should work:
import DSCore
element = IN[0]
result = []
for walls in element:
	loops = []
	faces = []
	for face in walls:
		loop = face.Loops
		loops.append(loop)
		faces.append(face)
	c = len(List.Flatten(faces,1))
	d = len(List.Flatten(loops,1))
	if c == d:
		result.append(False)
		result.append(True)
OUT = result
#10
It did exactly what is ment to do. However it didnt work. For instance,
The highlighted door has a hole in it, but the code said it didn’t. I think that the semanthics of the code is not the proper one for this application.
Anyway, i’m really thankfull for all your help
#11
It depens on what you consider as a hole. I attach a picture to better explain:
In my opinion a hole is only case #2. I consider #3 and #4 to have a non-rectangular outline, but I would not say they have a hole.
I understand what you mean, but in order to get a script, we need first a definition. A script based on how many faces has a solid doesn’t work, because you can have irregular walls.
Maybe a different approach would be to find out if a wall is hosting a door/window/etc…? But that would work for Revit walls, not for generic solids.
#12
If we’re talking Revit elements you could actually just compare the original geometry with the actual geometry of the element:
Empty List to Value
#13
All these solutions are great work but we won’t know which is best because we were never told why it was needed…
@ramoon.bandeira would you be able to explain a bit more? It may be that the best solution is something completely different :slight_smile:
Apologies for butting in,
Mark
#14
I need to get all the walls in revit that has a hole of walls or windows inside of it. it is necessary for the budgeting workflow we use here in our city.
I managed to get both the walls that serve as hosts for walls and windows, and the joined walls for that.
I filtered the walls that were joined to it and was not paralell to the original wall. it is going well so far… but this last step i cant overcome…
#15
i’ll check it out
#16
It worked. THANK YOU!!!
#17
I was playing a little mindgame just now
A wall that has had a door, but was later filled in by a wall (same type)
:slight_smile:
#18
Is there a hidden bar behind it? I’ll have a Scotch and toast you guys :slight_smile: Zach Kron knows the handshake!
Filter by demolition phase perhaps?
