Hello everyone,
Using Dynamo 0.9 and trying to insert a view in the node DetailComponent.ByCurve by using a list with only one item. However the result is <null>. When I use the OOTB Views node and select the same view from the drop down menu it works without a problem. Does anyone get the same result? Is it possible to change the node so that it does accept the list of views? Thank you!
