Here is the code -
clr.AddReference(‘ProtoGeometry’)
Import DocumentManager and TransactionManager
clr.AddReference(“RevitServices”)
Import RevitAPI
clr.AddReference(“RevitAPI”)
app = uiapp.Application
dataEnteringNode = IN
#unwrap all elements to use with API
elements = []
for i in IN[0]:
elements.append(UnwrapElement(i))
idsToDelete = ListAutodesk.Revit.DB.ElementId
for i in elements:
idsToDelete.Add(i.Id)
“Start” the transaction
doc.Delete(idsToDelete)
“End” the transaction
message = “You have successfully deleted n " + str(idsToDelete.Count) + " elements from Revit model.”
OUT = ‘n’.join(’{:^35}’.format(s) for s in message.split(‘n’))
