I created UI to select floor plan views in our template to save. Now I need to delete the ones not on the list.
I know the answer is right in front of me. I’ve just been looking at it way too long.
Any help would be much appreciated.
First you need to establish which views are placed on sheets.
I’m using the Sheet Number parameter from the ViewPlan to check if a view is placed on a sheet. Any placed views will display a sheet number and any unplaced views will display - - - as per the image.
Hope this helps!
Another possible OOTB route to take
