Delete un used Lines subcategories
hello
can i remove unused Lines subcategories
I cant find any way to remove them by dynamo
yes, you can remove them…here where do you need help?
i can’t find an element to delete all i have is subcategories names
do you want delete the marked elements of need to filter from unwanted?
yes, but the issue that i can’t get the subcategory
but you can’t delete them
try like this, use the spring node to delete the subcategory.
Line.dyn (16.3 KB)
Thank you I was looking for this block image
how do you know if that thing is not being used in the project file?
It doesn’t
I take the approach that even if linesStyles are not used, that doesn’t mean they shouldn’t be there.
My general approach is to instead amalgamate all the rouge linestyles into the correct ones.
However, if you were to simply check if the linestyle existed in the proejct and delete it if it was not then you can use this approach. (Gets All Lines, Gets All Lines in Project for Each Subcategory, if the list of lines in the project for the subcategory is empty, then it it un-used. Filter the Subcat list by that boolean and then delete the resulting subcategories.
Python - Line Details
#║║║║╠═╝║ ║╠╦╝ β•‘ β•šβ•β•—
#β•©β•© β•©β•©  β•šβ•β•β•©β•šβ• β•© β•šβ•β• IMPORTS
clr.AddReference("RevitAPI")
#β•šβ•—β•”β•β• β•β•£β• β•¦β•β•‘β• β•β•£β• β•©β•—β•‘  β•‘β•£ β•šβ•β•—
# β•šβ• β•© β•©β•©β•šβ•β•©β•© β•©β•šβ•β•β•©β•β•β•šβ•β•β•šβ•β• VARIABLES
# Current doc/app/ui
app = uiapp.Application
LineStyles = []
LineGraphicStyle = []
LineRGB = []
LineStyleID = []
LineStyleName = []
LineUserMadeBool = []
listPattern = []
listpatid = []
patname = []
lineWeight = []
#β•‘  β•‘ β•‘β•‘  β•‘  β•‘β•£ β•‘   β•‘   β•‘  β•‘β•‘β•‘β•‘β•‘β•£ β•šβ•β•—
#β•šβ•β•β•šβ•β•β•©β•β•β•©β•β•β•šβ•β•β•šβ•β• β•©   β•©β•β•β•©β•β•šβ•β•šβ•β•β•šβ•β• COLLECT LINES
# Collect the BIC
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Lines).ToElements()
# Isolate BIC from collection
bic = collector[0].Category
subcats = bic.SubCategories
# Determine LineUserMadeBool values
for subcat in subcats:
    subcatid = subcat.Id.IntegerValue
    subcatidasint = int(subcatid.ToString())
    if subcatidasint > 0:
        LineUserMadeBool.append(True)
        LineUserMadeBool.append(False)
# Filter subcats based on LineUserMadeBool
subcats_filtered = [subcat for subcat, usermade in zip(subcats, LineUserMadeBool) if usermade]
for subcat in subcats_filtered:
    LineStyleID.append(subcatidasint)
    subcatele = Revit.Elements.Category.ById(subcatid)
    LineStyles.append(subcatele)
    LineStyle = subcat.GetGraphicsStyle(GraphicsStyleType.Projection)
    LineGraphicStyle.append(LineStyle)
    subcatname = LineStyle.Name
    LineStyleName.append(subcatname)
#β•‘  β•‘β•‘β•‘β•‘β•‘β•£ β•šβ•β•—  β•‘β•‘β•‘β•‘  β•‘β•‘β•‘β•‘ β•‘ β•‘β•‘β•‘β•£ β•‘
#β•©β•β•β•©β•β•šβ•β•šβ•β•β•šβ•β•  β•©β•β•šβ•  β•© β•©β•šβ•β•β•β•©β•β•šβ•β•β•©β•β• LINES IN MODEL
if isinstance(LineStyleName, list):
    names = UnwrapElement(LineStyleName)
    names = [UnwrapElement(LineStyleName)]
alllines = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Lines)
lines = []
for n in names:
    lines.append([x for x in alllines if x.LineStyle.Name == n ])
# Outputs for Dynamo
OUT = LineGraphicStyle, LineStyleName, lines, subcats_filtered
Python - Eraser Tool
#python nodes in dynamo 1.0
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import geometry conversion extension methods
# Import RevitAPI
elt = []
for i in IN[0]:
	elt.append(UnwrapElement(i).Id)
# Start Transaction
cantdelete=[]
for item in elt:
	try:
		doc.Delete(item)
	except:
		cantdelete.append(item)
# End Transaction
doc.Regenerate()
OUT=cantdelete
