Hi again don’t worry about these blue lines once u close the revit file after saving they will disappear, these line created by dynamo to study the beams coordination.
Thanks Bro, Hope to get more useful dynamo graph from you.
I am testing your graphs and i am missing the DUPLICATE ITEM INDICES node.
Which package will i get this node in?
Sorry for digging up graves here
Hey Gary,
i am sry for the late replay it from Archi-Lab_Grimshaw which isn’t available any more from archi-lab packages. but if you are interested i can send it to you.
Hi Mohammad,
I’m looking for Archi-Lab_Grimshaw and I can’t find it anywhere - is it possible you make it public?
Which Node do you need ?.
- Duplicate Item Indices
- Delete Items
For Duplicate indices:
Python Code:
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
mylist = IN[0]
a, seen, result, unique = mylist, set(), [], []
for idx, item in enumerate(a):
if item not in seen:
seen.add(item)
unique.append(idx)
# First time seeing the element
result.append(idx)
# Already seen, add the index to the result
#Assign your output to the OUT variable
OUT = unique, result
Delete Elements:
Python Code:
clr.AddReference("RevitAPI")
x = UnwrapElement(IN[0])
o = []
for i in x:
ID = Autodesk.Revit.DB.ElementId(i)
doc.Delete(ID)
o.append(True)
OUT = o
Thanks a lot this seriously helps me from a whole lot of pain on Valentines Day.
1- is this the node that i sent to you ?
2- You need the script to delete which type of elements
The code need to be edited a little to add another input as true/false. anyway i will send you another code by today
I think if you been reading from the beginnings i was clear that the nodes i got from the Archi-Lab_Grimshaw which again isn’t available anymore , and i think instead of digging this deep you could just come and help better than worrying about the copywrite thing, for sure all thanks to Konrad for these nodes. Have a good day Andrew.
Here you go
y= []
y.append(IN[0])
y = len(y)
o = []
if IN[1] == True:
if y == 1:
ID = Autodesk.Revit.DB.ElementId(x)
doc.Delete(ID)
o.append(True)
for i in x:
doc.Delete(ID)
o.append(True)
OUT = o
First of all i agree with all what you said and i hope everyone to stand for helping perspective nothing more like what you said and thank you for sharing the script with us i will check it out. Looks good
That sounds good to me, unless someone copy/pasted something from my website and put their name on it. That’s not cool. Other than that I don’t care. It’s code, and anyone can write the same thing. It’s not magical.
i try to delete materials w/ same name, got error message, both delete node and Python node not working, is it because “delete within list” issue?
elements = IN[0]
if not isinstance(elements, list):
elements = [elements]
res = [doc.Delete(UnwrapElement(e).Id) for e in elements]
Im had Resolved in this, you can visit and download.
https://chuongmep.com/Check-Element-Duplicate-Dynamo-Revit/
