i was trying to delete a duct using python. but i failed.
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB.Mechanical import *
clr.AddReference(‘RevitAPIUI’)
clr.AddReference(‘System’)
clr.AddReference(‘RevitNodes’)
app = uiapp.Application
elem = UnwrapElement(IN[0])
doc.Delete(elem)
OUT = elem
The Delete() method takes an ElementId as parameter, not the actual element.
Edit: and remember to close your transaction again. See more in the documentation here on transactions: https://github.com/DynamoDS/Dynamo/wiki/Python-0.6.3-to-0.7.x-Migration#revitapi
can you advise how to resolve it?
You can retrieve an elements id property by using dot notation. You could do something like:
elemId = elem.Id
doc.Delete(elemId)
This will only work for a single item though. If you have several ducts, you’ll need to iterate through them all. Is there a reason why you aren’t using one of the delete nodes that already exists? I think there’s one in springs, clockwork and rhythm.
first thing, we can’t depend always packages. in my opinion python code is better than dynamo nodes.
its working, thank you for your help
Fair enough if that is your or your company’s view, but personally I think you are missing out on a lot of good functionalities, which will be extremely time consuming to recreate on your own. But it is, of cause, your desicion :-).
Please mark post as solved.
i tried to find out the delete node in clockwork package, but i didn’t find that. I don’t know why. some times version issues are there.
As I wrote earlier, I couldn’t quite remember if there was a version in Clockwork, but there’s plenty to choose from
And im sure there are others
Follow the guide Erik created here in order to install Orchid:
It’s supported for both 1.3 and 2.0.
