Collect duct at level
I want to collect ducts at level 1, but I got empty result…what’s wrong with my code?
clr.AddReference("RevitAPI")
bip = BuiltInParameter.INSTANCE_REFERENCE_LEVEL_PARAM
provider = ParameterValueProvider(ElementId(bip))
evaluator = FilterStringEquals()
rule = FilterStringRule(provider, evaluator, 'Level 1', False)
elementfilter = ElementParameterFilter(rule)
run = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_DuctCurves).WherePasses(elementfilter).WhereElementIsNotElementType().ToElements()
OUT = run
@newshunhk ,
check out this topic
still need help :frowning:
@newshunhk ,
you are looking for that ?
# Import RevitAPI Classes
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
toList = lambda x : x if hasattr(x, '__iter__') else [x]
pipes = toList(UnwrapElement(IN[0]))
def GetPipesLevel(item):
    assert sdkNumber > 2021,  "This Script is only Compatible with Revit 2022 and higher"
    UIunit = Document.GetUnits(doc).GetFormatOptions(SpecTypeId.Length).GetUnitTypeId()
    Zvalue = item.Location.Curve.Origin.ToPoint().Z*1.00
    convertTo = UnitUtils.ConvertToInternalUnits(Zvalue, UIunit)
    return doc.GetElement(Autodesk.Revit.DB.Level.GetNearestLevelId(doc,UnitUtils.ConvertToInternalUnits(convertTo,UIunit)))
OUT = [GetPipesLevel(m) for m in pipes]
the script has to be cleaned up, i just replaced curves by pipes
no.
I want to collect all ducts at Level 1 using python, I can collect all ducts, but I wanna filter the reference level “Level 1” as well.
I tried to follow this blog and modify myself, but fail.
https://thebuildingcoder.typepad.com/blog/2010/06/parameter-filter.html
@newshunhk
try to create a second part
levels = [GetPipesLevel(m) for m in pipes]
OUT = []
for i in levels:
    OUT.append(i.BuiltInParameter.INSTANCE_REFERENCE_LEVEL_PARAM)
    #provider = ParameterValueProvider(ElementId(pips))
    #rule = FilterStringRule(provider, evaluator, 'Level 1', False)
this is not what I want :frowning: sorry
maybe my question is not clear…
anyway thanks
I think I know where is the mistake
the builtin parameter of reference level of structural framing and duct is different :frowning:
I changed
to
BuiltInParameter.RBS_START_LEVEL_PARAM
then I fixed the problem :slight_smile:
