Decouple Geometry Preview from Category: Generic Model
Hi community,
Is there a chance to decouple geometry preview from generic model category? If I hide the category through visibility/graphic, geometry preview goes away as well.
Simply draw a wall and a door. Hiding Wall/Door category does not have any impact on geometry preview whereas unticking Generic Model category also hides geometry preview. What I’m tryin to do is keeping geometry preview alive but hiding all generic models.
bump
bump again.
@jshial I have no solution but a suggestion.
Post an issue at https://github.com/DynamoDS/DynamoRevit/issues
maybe a solution is to recalculate the geometry of the elements present in the view with each change.
The node “All Element in View” is used here to detect a change in automatic mode.
import sys
clr.AddReference('RevitAPI')
app = uiapp.Application
elems = UnwrapElement(IN[0])
fecInviewId = FilteredElementCollector(doc, doc.ActiveView.Id).ToElementIds()
opt = Options()
opt.View = doc.ActiveView
outGeoDs = []
for elem in elems:
	if elem.Id in fecInviewId:
		geometryRefs = elem.get_Geometry(opt)
		for geo in geometryRefs:
			if isinstance(geo, Solid):
				outGeoDs.append(geo.ToProtoType())
			elif isinstance(geo, GeometryInstance):
				geoinstances = geo.GetInstanceGeometry()
				for geoinst in geoinstances:
					if isinstance(geoinst, Solid):
						outGeoDs.append(geoinst.ToProtoType())
				pass
OUT = outGeoDs
@c.poupin Thx~
yet my situation is like geometry preview and Generic Model category are still coupled. A not perfect workaround I’ve been using recently is hiding generic models by Filter. The filter must contain rules otherwise it will just hide all generic model (equivalent to uncheck Generic Model category in V/G), then geometry preview will be gone also.
@Vikram_Subbaiah Thx~
Issue posted.
