Hi guys, Im importing some points from GIS info and when I try to transform it to points it doesnt let me do that because of the number of decimals. May be a simple problem but I still dont get how to solve it. Thanks
I’m not sure I understand your issue. Looks like everything is working in your image.
Sorry I should have explained myself better. Im getting the same point 8 times, despite of it takes 8 different numbers in X and Y.
Dynamo is only showing you 3 decimals because that’s how it formats points. The values and geometry are still correct. If the points in your GIS data aren’t that close then it may be a scaling or units issue.
You are right. It has to be a scaling or positioning issue. Im gonna investigate and come with the solution if I got it. Thanks.
