Dear Dynamo users, I am trying to get the location and name of some Autocad block references to place families on the same spot. The Cad file is linked into Revit and the proposed workflow in Dynamo is by using the linkdwg nodes. First node: GetCOMAnnotationsByObjectDBX and it turns null. Is there something profoundly wrong? Is there any workaround? Thanks in advance
Hi @DimitrisC,
The easiest way is to use the Cad Block node of the Genius Loci package. No need to open Autocad anymore.
nope.
it just worked eventually. Thanks a million times
Hi Dimitrios,
Please check the Autocad file. There might be a nested block (blocks within a block) and the custom node only reads the top level block.
Or the blocks have attributes and Revit can’t read them.
