Hello all,
I hope someone might be able to help I am having issue with the Do cloud render node. It reports the following error:Warning: CloudRendering.Run operation failed.
Could not load type ‘Autodesk.RaaS.RevitAddin.Attribute’ from assembly ‘RaaSApplication, Version=19.0.0.0, Culture=neutral, PublicKeyToken=null’ and also when open Dynamo it gives a I/O issue as per attached image.
Does anyone had this problem and managed to sort it?
I will highly appreciate any help in the matter.
Kindest regards,
Giada
