Hi there,
I have seen a few post about it but I haven´t still figure out if it is possible to get data from more than one Revit Link at once so I can create a sort of sheet transmittal.
Any suggestions?
Thanks!
Hi @manuel.monteroH2Y3P ,
Have you tried the list lacing of those docOrlink inputs to @l1/ @l2 and/or changed the lacing of the nodes themselves to longest?
Hi @Daan,
Thanks for replying, I have finally figured out using a bit of python and without the need of having all Revit Linked in my open project file.
I leave the code to get all the sheet from documents, just in case someone need.
clr.AddReference(‘RevitAPI’)
docs = IN[0]
sheet_elements =
for doc in docs:
collector = FilteredElementCollector(doc)
elements = collector.OfCategory(BuiltInCategory.OST_Sheets).ToElements()
sheet_elements.extend(elements)
OUT = sheet_elements
Hi @manuel.monteroH2Y3P does that python node close the open document again ?
Hi @sovitek, I have used OpenDocumentFile and CloseDocument from Rhythm for that. I have also updated my post to include de python code
