Data Shapes Select Model elements Data
I’m trying to use Data shapes with Revit 2024 to select views and then select sheets.
When selecting it only allows me to select one element and then reverts back to dialog. I have it to False on the boolean for SelectSingleElement_. After Set Values no values are in my watch node. Would love to understand what I’m doing wrong.
Thanks,
Hi @mcrowleyQ6PET , If you wan tto select view and sheets in your model try this
but if requirements are to get sheets/view or viewport use these nodes based on your requirements
for your sheets you can get view by this
Vinay
Thanks for the response. The hope is to select the views and sheets in the project browser to reduce the amount of sorting in the UI selection. I realize now the UI select model elements captures elements in the model not items in the project browser.
This will help you select view and sheet
