Hello
I’m trying to setup the Batch Add Parameters from data-shapes as described here: Batch add shared parameters from .txt file with UI.MultipleInputForm ++ – data|shapes
However I’m getting an error at the FilePath Data node?
Appreciate any suggestions
Hello @eklund.rickard are you sure you had the latest datashapes package installed ?
Hello
I think this is the latest version?
Hmm, its working now. I restarted dynamo. I’ve changed screen setup from 1 large screen to two smaller ones. Seems like that if dynamo is on two screens t the same time, strange things happen
