Now my holiday is over, I’m picking things up where I left them. I see that your package has been updated. So I updated my dynamo script too.
I noticed that the Rhtyhm application.CloseDocument errors. ‘Warning. Operation Application.CloseDocument failed’.
Putting a watch on DanEDU.FamilyDocument.AddSharedParameter log output results in ‘null’. (So I assume that’s why the Rhithm node isn’t working)
The input is good: Autodesk.revit.DB.Document list.
Revit 2017.2
Dynamo 1.3.1
DanEDU 2017.802.1
Rhythm 2017.8.15
Thanks for your reply ! AddSharedParameter.dyn (7.8 KB)
It’s my dyn file.
The family I want to add shared parameter is in the default folder.
C:\ProgramData\Autodesk\RVT 2017\Libraries\US Metric\Doors
Working with background opened files in Dynamo is definitely a bit unstable and unpredictable as Dynamo is trying to swap documents constantly… Unfortunately I do not have a straight forward answer for this.
Although it does seem the read only factor plays into this error quite a bit!
@erfajo Is there an easy fix to modify the Python to run this node on a single, open RFA instead of a group of RFAs within a folder structure?
We’re looking for something like this, that we could use to batch apply multiple shared parameters since it takes so many mouse clicks the old fashioned way.
I couldn’t get the OOTB node “Document.Current” to work as you suggested above.
The custom node of the “Archi-lab_Grimshaw” package “Current Document” gave better results (not always stable).
I hope it can be of help.
