I have a Curtain Wall (The one in the Revit sample).
I want to change this parameter ![]()
But alas when I put ‘Layout’ into my code I only get the Horizontal Grid. I want the Vertical Grid.
Is it possible to do this without Python?
You must use the built in parameter : "SPACING_LAYOUT_VERT".
archilab has some nodes to set them.
Nope, “Layout” does the horizontal grid, not the vertical one.
@Alien ,
hmmm…
Ahhh! I couldn’t find that anywhere! Thanks ![]()
@Alien ,
Rather SPACING_LAYOUT_VERT
You can also use the Revit Lookup addin to find the built in parameter names.
Still can’t get the vertical grids.
I have tried:
SPACING_LAYOUT_V
SPACING_LAYOUT_VERT
SPACING_LENGTH_V
I’ve tried all that look like they should work but
there is
V and VERT… and H and HORIZ… none of them work!
@Alien ,
you call them by the buildname thats can only used in Python…
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
# Die Eingaben für diesen Block werden in Form einer Liste in den IN-Variablen gespeichert.
#.get_Parameter(BuiltInParameter.SPACING_LENGTH_VERT)
walls = UnwrapElement(IN[0])
setPara = []
for i in walls:
setPara.append(i.get_Parameter(BuiltInParameter.SPACING_LAYOUT_VERT))
OUT = setPara
KR
Andreas
See my original post - without Python ![]()
It is a type parameter. You missed the ElementType node.
Oh dear!
I am really tired today!
(I literally am facepalming)
Thank you!
