How to get curtain wall grid horizontal and vertical grid count?
Hello
Both x and y grid is called “Number” in curtain wall parameters. How to get them knowing which is which?
edit: also I have counted manually and the grid number is +1 compared to the display value. Why is that?
I’m working with fixed with panels.
you can do it with a simple python piece:
walls = UnwrapElement(IN[0])
clr.AddReference("RevitAPI")
output = []
for w in walls:
  output.append([w.CurtainGrid.NumULines,w.CurtainGrid.NumVLines])
OUT = output
I assume that the input is a list of curtain walls. It gives you a number of internal grid lines.
obraz
