Good day, I’m trying to cut my set of bars, in a slab opening, I have managed to get the curves, but I want to place the bars with the same set that the originals have (By quantity and spacing). I can now place them individually, but I need to put them by a set rule. I thought about grouping them and then take the first item and apply the rule of the set, but I do not know how to do it.
I am trying to do the same. DId you get it jamess166?
Good morning, at the time you are starting everything, I gave up. I’ll see if I can come up with something and I’ll tell you.
@jamess166 I found this python code which detect each rebar in a set.
