Does anyone know if there is a list to reference the datatypes and what they do for custom nodes?
For example, I have a percentage custom node and for the datatype it can either be double or int. What is the double datatype? Is there a list that shows all the datatypes and describes what it is?
I don’t think it’s even necessary here. What is your output type?
Edit: Never mind. It does seem to make a difference inside a custom node. The datatype for double is just double.
Hello @tc_taylor,
If you wish to have more than one specified datatype, you can use var
which stands for variable and allows multiple input types.
/* First Number*/
x: var = 1
If you wish to understand the the list of reserved keywords
, you can check out either of the following:
- The DesignScript language guide: https://dynamobim.org/wp-content/links/DesignScriptGuide.pdf
- My DesignScript presentation for BILT Slovenia 2018: https://github.com/Amoursol/dynamoDesignScript/blob/master/DesignScript_ARobustDiveIntoTheLanguageUnderlyingDynamo_BILTEUR_Ljubljana2018.pdf
Both should help shed some light!
Hello @solamour,
Thank you for the guide. That was what I was looking for.
