Hi all,
Dynamo has a strang behaviour. When i start dynamo most of the times it loses the Custom Node path. which was set in “Manage Node And Packages Paths”.
I’m using Civil 3D 2021.
Any clue?
Hi all,
Any clue?
Is it a network path that you lose connection to like a VPN?
I forgot to past a screenshot. No it’s a path to the “Microsoft One-drive”.
Update: Before i run Dynamo the paths in the “DynamoSettings.xml” are correct. But when i open a script the path is removed from het “DynamoSettings.xml” file.
can you try without any addins?
