curvy block Civil 3D
Hola amigo @edcanonb buenas. youre corridor is a polycurve made of multiples curves of diferent sizes, so you have to:
  1. Offset your Polycurve to each side.
  2. Get the curves of the Polycurve, Offset these Lines.
  3. Ask the start or the end points of these curves.
  4. Create a New Polycurve and create Coordinate System at segment length
  5. Finally you just instert the block in these Coordinate System (For one of the sides you have to rotate 180 degrees the coordinate system).
    Is not perfect but is better i think, any way the rigth way to do this is create an assembly.
