Hi everyone,
I have a problem.
I want to trim or extend curve start and end point. I want to a complete line.
I attached screenshot.
Do you have any idea ?
Thank you so much.
Hi everyone,
I have a problem.
Thank you so much.
Hello @DynaGirlBIM …probably line merge from spring can help you here…
@DynaGirlBIM make it a polycurve then use offset.
Hi @sovitek ,
I understand your post. But How to use margin input ? 100 or 1 what is this ?
Thank you again ![]()
@Elie.Trad Hi , I can’t make polycurve because they did not join curves.
Hello think its the margin it will join in my case 500 works…think what @Elie.Trad suggest is join the middle curve as polycurve and offset and think its the best way in your case, but havent look the right way in your image…
As @Elie.Trad mentioned, you can use the original curves to create a polycurve and offset the new curve.
Regards,
Thank you for feedback @Organon , I am working on it ![]()
