Hi, i’m trying to place some points on a line using data from a excel sheet, but i cant get the curve point function to read the list. Any ideas how to fix this? Works fine when using “list create” btw.
I think you are sending text, instead of number to List.Transpose node output
try plugging in the Object.Type node to see what you’re sending
Cordially
christian.stan
Looks like i’m sending text, is it possible to convert this to numbers? system string → system.int64
Plug this node ToNumber
Cordially
christian.stan
Thanks, working perfectly now
