Does anyone knows if this problem was caused by the shapeFilePath?
Could you turn on the outputs of all the nodes you got ? Especially Shape.GetAllShapes ?
I suspect the error you have is coming from the curves you are using. They maybe do not form a closed polycurve.
The output of Shape.GetAllShapes was a function not a curve, that was the reason! I fixed and all worked! Thank you for the help!
