I was trying to create geometry watching this video.
but i am confused in the facade creation. I cannot find a node ‘curve.dividebydistance’ which outputs a ‘curve’. so i was trying to workout with ‘Curve.PointsAtEqualSegmentLength’ which outputs a point.
Is this correct.
i am attaching the dyn along. can u look whats wrong?
Difficult to say, for sure in the last node the points are not correct because points 1,3,4 are exactly the same.
That might be because in the code blocks hor_div you also provide the same input for node 1,3,4.
Take a look if those inputs are correct
