Hello
I am trying to generate an array of points using point data and range node
The cross product function does not work when I use data from the point but does work when I use the same numbers from code block
It is hard to tell from this picture, but my guess is that you have to set the list levels. From the second pic it looks like if it is considered as one item, so cross product has no effect. Please check if the list levels in the upper Range node are the same on both pictures, I guess they are not.
you are right… thanks
