Crop Region Size Parameter Edit by view
i`m trying to edit the parameters so as to make all the views with 3 mm annotation crop for example !!
is there any way ?
Hi @Ahmed_Salah1
There is a node from @T_Pover MepOver package called View.SetCropBoxCurves you could use that to set.
@Kulkul the crop region i dont want to change im controlling it through scope box i want to change all the annotation crop offset only to be for example 3 mm !
@Ahmed_Salah1 Sorry i thought your looking to set view crop boundary. You need to access revit api
http://www.revitapidocs.com/2017/d815093f-0331-76c9-7607-67e62f9f2c9b.htm
@Kulkul Thanks but i dont think i can write a code yet im still learning , so i will wait someone to help me but Thank you to provide half of the solution .
Hi Ahmed,
You can use this code to set the annotation crop size:
clr.AddReference('RevitAPI')
import Autodesk.Revit.DB
clr.AddReference('DSCoreNodes')
import DSCore
from DSCore import *
# Import ToProtoType, ToRevitType geometry conversion extension methods
if isinstance(IN[0], list):
	views = UnwrapElement(IN[0])
	views = [UnwrapElement(IN[0])]
size = IN[1]
listout = []
for view in views:
	regionMan = view.GetCropRegionShapeManager()
	try:
		regionMan.BottomAnnotationCropOffset = size
		regionMan.LeftAnnotationCropOffset = size
		regionMan.RightAnnotationCropOffset = size
		regionMan.TopAnnotationCropOffset = size
		listout.append(view)
	except:
		listout.append("failed")
OUT = listout
The size must be supplied in feet, so if you’re a metric guy (like me) then divide by 304.8 like in this example:
@T_Pover you helped me twice this morning , Thanks
Thank you T_Pover, for this piece of code
This just saved me several hours worth of work. Thank you!
Hi, I’m new to writing code, what language should I use? C#, Python? Should I copy and paste this? :frowning:
I’m not sure where else to post this but it is related to the annotation crop so I will ask you here since you seem to have figured some of this stuff out (and also developed the View.GetCropBoxCurves node for your MEPover package). Would you know how to extract the curves for the annotation crop shape via python? It is available via the api per https://www.revitapidocs.com/2019/4e698377-7527-c562-21bc-379c68efda5d.htm but I have 0 understanding of python and how to do it. I mention the View.GetCropBoxCurves node because it seems similar approach could be taken but I may be wrong since my understanding of python is not great.
Thank you!
Sure, here is a slightly modified version of the node GetCropboxCurves to get the annotation crop:
	view = UnwrapElement(IN[0])
	toggle = 0
	view = [UnwrapElement(IN[0])]
	toggle = 1
listout = []
for x in view:
	region = x.GetCropRegionShapeManager().GetAnnotationCropShape()
	if region != None:
		lines = [y.ToProtoType() for y in region]
		listout.append(lines)
		listout.append([])
if toggle == 0:
	OUT = listout
	OUT = lines
Thanks. I tried to do it myself and totally broke it. I got lost at the if and else statements for region.
Dude! God Bless Your Soul!
w Love
UNITY
*Hi, am struggling to add the size In(1) can somebody give me examples for the sizes related?
Thank you very much for your question and your help.
I have a question:
Is it possible to set the annotion crop by buildings like this:
I have edited the crop view but the annotion is still the same as the viewport
Nope!
If it can’t be done manually then not possible via API.
