Crop Region by curve
Thanks jup,
Was looking for this… just needed to TAB outputlist.append(view) into the loop
No worries - well I had parked this - been busy since. I’ll check it out though.
Mutually beneficial it would appear :slight_smile:
Hi everyone,
I’m jumping in the conversation about the combine list that I can’t figure it out how to make it work.
@jup : I’m looking at your modification about combine list.
If I’m getting this right, your python as only [0] as entry ?
I tried your python and get this error
" File “”, line 30, in
TypeError: iteration over non-sequence of type FloorPlanView"
(my input in [0] is my list of some dependant view)
@Einar_Raknes at first i used your python code from your dynamo definition and it works great but I still have to select the view one by one.
I tried the zip() - had to rename “curvelist” to “curves” and “views” to “view” and then I get the error :
" File “”, line 34, in
NameError: name ‘outputlist’ is not defined"
Line 34 is the “outputlist.append(view)”
What am I missing there ?
Maybe you have forgotten to define the list?
outputlist = []
THANK YOU !
It works like a charm !
Hey Einar
i try to use the node for multiples views , but i have an error message as shown in capture below
clr.AddReference(‘RevitNodes’)
clr.AddReference(‘RevitAPI’)
#prepare input
views = UnwrapElement(IN[0])
curvelist = IN[1]
outputlist =
for view,curves in zip(views,curvelist):
#Create curveloop
loop = CurveLoop()
for c in curves:
	loop.Append(c.ToRevitType())
#Set cropregion in Transaction
view.CropBoxActive = True
view.GetCropRegionShapeManager().SetCropShape(loop)
OUT = outputlist
If I want to make this script with Areas instead of rooms … that will help me
@Mohamed.Elmasri can you try and see what happens if you replace OST_Rooms with OST_Areas in the code? And if you have any further questions, please start a new thread since this one is old and already solved
Dear Kukul,
I was looking for Script doing same work you sent as a flash. Could you please help.
Thanks.
@kvusal
Please read the forum guidelines to check if you introduced your request appropriately:
Please send also a screenshot of what you tried so far in your initial thread:
Thanks :slight_smile:
Thanx for sharing your knowledge and your script. I used your script but got a warning that the FloorPlanView object is unscriptable. Do I have to edit the script somehow or do I have to change the Input views?
There could be some first clues to be found through the search field:
https://forum.dynamobim.com/search?q=object%20is%20unsubscriptable
See also if the answers already given in this thread can not help, for instance:
Thought the creator of the script would like know the issues, and Yes I searched this thread. Because I did not found the answer, I posted the issue.
Actually I used the View.SetCropBoxCurver from the MEPover package:
hello Kulkul,
what is in the the phyton script you use?
I wood like to copy a crop view in Revit and it seems like You do the with this script in dynamo. And i am curious how You doing that?
kind regards,
i am trying to run the script but.its now working.
and got the error as shown in screenshot.
can any one suggest the change in script
