Hi all, I want to know how can I get a StructuralFraming from the solids in Dynamo with the same geometry?
Hi @Haqiqi_alireza seems you need feed in a template path, and be surethe material you feed in exist in the template, if not then try with “default” material
thank you for your reply. I don’t really need any new material. I created my Beam as Solid to achieve the StructuralFraming with specific geometry (width and length). cause there is no CructuralType with this geometry by default.
allright but guess that node need an material…so use “Default” instead ABC and feed a path to a template…and if you will insert your family types you could try family instance by point, if you will have one type instead of 4 types you could flatten your solids and use a solid union…if 4 types then you will need 4 unique names as well
