Can’t read your nodes so we can’t tell where the issue is. Zoom in so we can clearly read stuff and then use the export canvas as image feature (edit menu or top right corner of the workspace).
Are you in the project environment or the massing environment?
I’m not sure you can make walls on an import into a massing family when in a project, even using the UI. Building the form directly in a massing environment is likely a better path forward, but the data quality of the OSM will matter in such cases. Can you share the rft, rvt, and osm?
If I close the Dynamo script, the geometry disappears, so I can’t send it here.
Thank you @jacob.small I managed to solve it by changing the category to a mass exterior wall.
