Hello lovely community :),
I am making a script which goal is to take over elements from Ifc Link model. At the beginning I am trying to creat Revit walls from ifc walls but smth doesn’t go as planned, I am getting more walls then it should be, instead of one Dynamo creates four walls. In attachment is the graph.
Thank you very much for your help :)..
Damir
There were 186 walls from the ‘in’ list of the List.FilterByBoolMask node, and there are 186 walls in the Wall.ByCurveAndHeight node, so I don’t think you’re getting more than you should.
Could it be you have duplicate walls on top of each other in the initial selection?
Thank you @jacob.small for your reply.
Man, funny thing, I forgot to filter by the level because Revit creates walls from one choosen level.
Now it works so I can go level by level.
Here is the script if someone needs it…
