Creating random material on facade cladding
Hi
i need to give each “diamond” shape a random material based on 3-4 different color.
but i cant get it to work - :frowning:
ive tried looking into all posts regarding facade cladding on the forum, but neither helped.
i hope you can help me. thanks in advance :slight_smile:
Hello, could you please indicate your references? For instance, did you also see this one?
Hi #Yna_Db
yes that was the first one i came by, when searching for answers.
as you can see, its not working in my case :frowning:
my wall is not a curtain wall, but build as a massing exterior wall.dunno if thats the reason?
When I look at your graph, it seems obvious to me that the second List.GetItemAtIndex node should return an error because there can’t be an item at index 2. To work efficiently with lists, you should unroll your nodes to see what’s in. Here are some indication that could help you:
http://dynamoprimer.com/en/06_Designing-with-Lists/6-2_working-with-lists.html
http://dictionary.dynamobim.com/#/
Hi guys,
I would have created different curtain panel types with different materials and maybe done something like this:
EDIT: I now saw that your wall is not a curtain wall, I’m sorry. Maybe you can use some of the logic anyway.
