I’m trying to create a pipe from a Start.point and End.point. However, I can’t seem to find out how.
I tried using create pipe node from Hot gear package but it didn’t work at all.
Any ideas?
Any ideas?
Hi Joe,
You can accomplish this task by using a two point adaptive component and a list of points.
Sincerely
HI Cyildirim,
2 Point adaptive component? Can you give me some more info on that, haven’t come across them before.
You need to create a generic model with two adaptive points in revit. You can use YouTube for learning how to create a two point adaptive component.
There is a pipe by lines node in the excellent MEPover package which you should try out.
It was perfectly, Thanks!
Ended up getting Pipe.ByLines working, this is ages ago. But gave up script up due to connecting the pipes being quite a difficult task
