Is it possible to make a Surface between a closed polycurve and a circle? I have tried the “Surface.ByLoft” node. It looks like there is a problem creating a surface between two “closed” curves? The goal is to make an functional analytical Surface with an extursion in Robot.
Thanks a lot for any help!
We also tried to Connect the Analyze node “AnalyticalPanel.BySurface” to the Surface in our model, but same problem occurs. It lookes like the geometry is drawn as a closed curve in Robot, from a point on the Surface:
