Hi guys, I’m trying to create a coupler for 2 steel bars, but I get an error like in the image. Below is the code I made. Can you guys help me fix this? Thank you very much
import System
clr.AddReference("ProtoGeometry")
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import*
view = doc.ActiveView
rebar = UnwrapElement(IN[1])
def CreateRebarCoupler(doc,rebars):
coupler = None
if rebars.Count > 1:
defaulttypeId = doc.GetDefaultFamilyTypeId(ElementId(BuiltInCategory.OST_Coupler))
if defaulttypeId != ElementId.InvalidElementId:
rebarData1 = RebarReinforcementData.Create(rebars[0].Id, 0)
rebarData2 = RebarReinforcementData.Create(rebars[1].Id, 1)
error = RebarCouplerError
coupler = RebarCoupler.Create(doc,defaulttypeId,rebarData1,rebarData2,out error)
if error != RebarCouplerError.ValidationSuccessfuly:
TaskDialog.Show("Revit", "Create Coupler failed: " + error.ToString())
return coupler
create = CreateRebarCoupler(doc,rebar)
OUT = create
