Creating a number sequence for each index of a list?
I’m producing a script for populating the door mark parameter in various ways depending on the type of door in a project. I’d like some items we’re scheduling with the doors, such as notice boards and lift doors, to be scheduled as “text parameter” “00n” with n being an increasing number. I want the 00n sequence to start again for each type of element for example: Lift doors 001, Lift doors 002. Notice Board 001, Notice board 002, Notice Board 003.
At the moment I’ve managed to list them all consecutively: Lift doors 001, Lift doors 002, Notice Board 003 etc. but don’t know how to restart the sequence for each type. I’ve created a list with each type at a different index number but I don’t want to split it via specific index number because different projects could have different numbers of types. I’ve attached an image which hopefully clarifies this a little.
Thanks in advance,
Kieran
string pad
Thanks for the help so far, that has simplified the approach I was taking to generate the names. I’ve attached an image showing how this applies to my project, I’d like to be able to now produce names with the format: Notice Board 001 , Notice Board 002, Lift Doors 001. So the sequence restarts when the type of element changes.
Many thanks for your help so far,
Kieran
list split query 2
@K.Marsh
Kieran,
Combine List.GroupByKey with this
Maybe this:
That’s great thanks! Would you mind explaining that first Code Block for future reference?
Have a look here under “How about lacing”: http://dynamoprimer.com/en/07_Code-Block/7-2_Design-Script-syntax.html
Why doesn’t it work for me? @jostein_olsen
I get either
Warning: The value in a ranged expression must be number or a letter.
or
Warning: There is no version of Get.ValueAtIndex that accepts argument type(s) (function, string[]).
Take another look at the example
This 1…List.Count(x); was the solution for me, but thanks!
