I am trying to create a Dynamo script that calculates the centroid of each wall shape in Revit and places a marker at the calculated centroid. The image below is an example of the wall geometry I am working with.
This is my first time using Dynamo, so I would appreciate any guidance on what I may be doing incorrectly or how I can improve the workflow. My goal is for the script to identify each individual shape or family, calculate its geometric centroid, and automatically place a point or marker at that centroid.
Any advice, corrections, or suggestions for a better approach would be greatly appreciated. Thank you.
Hello @KiaraAnashpaul and welcome to the forum…not really sure so here is some option you could try
select models elements - get location _ point at parameter 0.5
or maybe
select models element - element solids - solids centroid
What kind of marker will you insert ? a 2d view specific ? or a 3d marker ?
Assuming you mean the true definition of centroid, then the Dynamo node Solid.Centroid should work. The graph would be:
Element.Solids to get all solids which make up the element.
Solid.ByUnion to combine any split elements into a single solid.
Solid.Centroid to get the centroid of the solid.
The assumption above is a big one though; remember that a centroid doesn’t necessarily have to be on the geometry itself (thing of a donut) so your market might not touch the element.
@KiaraAnashpaul
You can use BriMohareb_xxxx pak. To get all cross section properties "BriMohareb_XXXX" Package for RevitXXXX Thread
If you need only cg use @jacob.small recommendations
