I am using Revit API through dynamo using a Python script node to make a schedule; however, I have difficulty displaying a few field values.
I first identify the fields available for MEP Fabrication Pipework. and then refer to its index to get it populated. It works fine with every field except:
Item Number
Weight
Length
Can anyone cast some light on this issue?
You will need to share your graph for anyone to help you here.
