Create Schedules with specifik parameters
Hi there all
Im trying to get dynamo to create schedules for me, but im a bit lost here…
What im trying to do, is creating schedules with specific parameters in the set-up.
So I want Revit to find specific parameters (for instance “CCSClassName” and several others), Im trying to do this via the “schedulable fields” node. But i dont know how to filter the node, so that I get the right number for that parameter, so I can insert it in “Add fields”…
So Can Anyone tell me how to filter the schedulable fields for specific parameters, so that I get their List number, to insert in the Addfields node…?
Hello @bjkris …do you mean something here ??
Hi there @sovitek, That is exactly what I wanted!
But When I try to replicate yours, I get negative values in “Lis.IndexOf” Can You tell me why that is?
could you show your whole list from string from object…or try all indicies…
Also empty in “List.AllInducesOf”:
allright… try a list flattern after your sceduleable fields or play around with some levels
Ohhhh! You just saved Christmas! :stuck_out_tongue:
Yes merry Christmas :wink:
I am trying to create schedule, but the ScheduleType node shows null. Can you please give me some advice? Thank you.
Hello @Jutamas and welcome to the forum :wink: try create a new topic and show all you have tried and we can try help :wink:
At first, the ScheduleType node showed null, but I noticed again that it was working. So I tried again and ran the script, and it worked. However, when I closed the Dynamo file, the schedule I created disappeared from Revit as well.
hmm i havent heard aboat that before…which revit version are you in ?
PS is it better if you run from player ? anyway i cant create that issue
Revit_QqwyOkUHgJ
It worked! Thank you very much for the quick response. You helped me solve this problem. :blush: :bowing_woman:t2:
