Create same mark values for same size & length pipes
Hello dynamo community, i am working spool creation script with mark values. i need to apply same value for same size & length of pipes,but i dont know the how to create the script. here’s my script please give a solution for this.
@sovitek hi sir i need your help for this script
Hi @ bim6MRER3 not really sure probably something here your mean…
Look into GroupByKey. You can group your pipes by size and length and then create unique values for each grouping.
If possible you should use a custom parameter other than ‘mark’ or you will create many unneccessary revit warnings.
