Hello everyone,
I would like to create a new print batch using an Excel sheet for the sheets I want to include in the new set.
Thanks,
Hello everyone,
Thanks,
Please read this post completely.
Then think through the problem, take a stab at it, and go from there. If during the taking a stab at it you get stuck, search the forum for a partial solution to get past your roadblock. If you’re still stuck after that, post what you tried here along with a dataset (excel and Revit which coordinate).
This might help with starting. Collecting from Excel will be your homework, though.
Create Sheet Set (print set) in Dynamo 2.6
Thanks, I have tried those scripts, but I didn’t find one specifically that focuses on using an Excel sheet.
I’ll quote this directly:
What have you tried? Of the posts which Patrick linked it’s a certainty that none of them specifically accomplish your need, but all of them are readily adoptable with some effort. If you are trying but getting stuck then post what isn’t working here, along with your graph and a data set to use (you can leverage one of the sample models provided with Revit and refer people to that but include what version of the software you are in). If your permissions level is not yet sufficient here or file sizes too large you can use OneDrive, Dropbox, Google drive, ACC, box, or services like WeTransfer.
